Rolling a Fulvia Coupe on its side without removing windshields
CD's with documentationElectronic distributor
MAIS
Unread post by MAIS »
Does anyone have experience in rolling a Fulvia Coupe on its side (on top of tyres) to restore the bottom, WITHOUT removing the windshields/windows?..
Huib
Site Admin
Re: Rolling a Fulvia Coupe on its side without removing windshields
Unread post by Huib »
I just did it. I was wondering about the wind shields too but since I have plenty I risked it. Works well. Note that the interior was removed as well as subframe and rear axle.
You need two tyres on top of each other to support the roof.
No guarantee it works in your case.
MAIS
Thanks Huib, I'll do exactly how you describe. Let's try... Thanks for the quick answer!(tu)
Huib
Site Admin
Here is a picture although you can't see the wind shields are still in. It is difficult to go inside the car.
on the side.jpg (107.61 KiB) Viewed 962 times
MAIS
great, many thanks! If I understood you clear, you'll need in total 6 tires: 2 (as in the picture) to support the body and 2+2 (on top of eachother) to support the roof. Right?
Huib
Site Admin
4 tyres in total. Under the edge of the roof is just a single pile of two tyres.
MAIS
ok, clear! You were very helpful indeed.
fulvia a.i.
Unread post by fulvia a.i. »
add many pillows, blankets, foam rubber.....please :)
Return to “65 Fulvia”
