Rolling a Fulvia Coupe on its side without removing windshields
Does anyone have experience in rolling a Fulvia Coupe on its side (on top of tyres) to restore the bottom, WITHOUT removing the windshields/windows?..
Re: Rolling a Fulvia Coupe on its side without removing windshields
I just did it. I was wondering about the wind shields too but since I have plenty I risked it. Works well. Note that the interior was removed as well as subframe and rear axle.
You need two tyres on top of each other to support the roof.
No guarantee it works in your case.
Thanks Huib, I'll do exactly how you describe. Let's try... Thanks for the quick answer!(tu)
Here is a picture although you can't see the wind shields are still in. It is difficult to go inside the car.
- on the side.jpg (107.61 KiB) Viewed 952 times
great, many thanks! If I understood you clear, you'll need in total 6 tires: 2 (as in the picture) to support the body and 2+2 (on top of eachother) to support the roof. Right?
4 tyres in total. Under the edge of the roof is just a single pile of two tyres.
ok, clear! You were very helpful indeed.
fulvia a.i.
add many pillows, blankets, foam rubber.....please
