valve timing
rich
valve timing
Unread post by rich »
If the valve timing is incorrect can the valves hit the pistons? i am currently having problems with my 1300 series 1. Any help would be appreciated
thanks
Rich
lancialulu
Re: valve timing
Unread post by lancialulu »
Yes they can!
Use the markings on the front cam carrier and the cam shaft to get an aproximate setup to avoid hitting the pistons. If you have hit pistons then you could have bent a/some valves.
The manual has the procedure depending on your fulvia model to set the timing accurately.
Tim
Huib
Site Admin
Re: valve timing
Unread post by Huib »
As Tim says, they can. And they will! Again as Tim says, lining up the marks is just good enough to avoid interference statically.
Use the method as described in the Technical Databook page Fulv.01/0400. 1 mm if you have a 302 engine. 2.2 mm if you have a 303 engine. Using the vernier in combination with the sprockets you can time them to well within half a degree.
Return to “65 Fulvia”
