Clutch cover 2000
william
Clutch cover 2000
Does anyone know if the clutchcover for the 2000 (flavia) engine is interchangable with another more readily available (lancia/fiat) product? Like for example the Fulvia SII clutch us the same as lancia beta 1600 and Fiat uno.
william
Re: Clutch cover 2000
Just had the opurtunity to compaire both 1800 and 2000 covers and they look exactly the same. the only difference i can come up with is the 2000 beta cover is stronger. I opted for the stronger 2000 as my Flavia 2000 engine is modified a bit.
Thanks again. Next problem is finding a new clutch release bearing. Any tips?
Bert Ewalds
For the Lancia 2000, models 820.210/211/230/231 the correct bearing should be SKF 616524
william vd Sman
I've checked the net and found out that that nr is not carried by SKF for years. Could it be the same as Fulvia?
Bert Ewalds
Not very likely, the SKF cross reference list gives different numbers for the Fulvia bearings
I bought mine (Flavia 1800 Coupe) from Cavalitto, few years ago
Bert
Bert
Jens
Dear William,
according to Sachs, Beta 1800 and a lot of other Lancia and Fiat models use the same clutch pressure plate. Beta 2000 will not fit due to larger dia 215 mm in sted of 200.
Take a look at the sachs web site for more info: http://webcat.zf-trading.com/index.asp?SPR=4.
Just click on part no for crossref
