Hello,
I can't find the ecu - its not at the right hand end of the dashboard like the Turbo versions.
Leo Capaldi (lost inside a Thema)
Where is the ECU? On a 1990 16V (non turbo)
Pol
Re: Where is the ECU? On a 1990 16V (non turbo)
Hi Leo,
I own a 1991 16V, so I suppose it's the same. It's equipped with Bosch LE 3.2 Jetronic, and the ECU is fitted on the airflow-meter. If you look at it, it has a rectangular cover on top with a 15 pin connector.
Unlock the connector and remove the 4 screws, then you can take the ECU off, it is inside the cover.
Hope you didn't got stuck behind that engine
Pol (Looking under the bonnet at the ECU)
leo capaldi
Thanks Pol - that explains a lot. The guy whose car it is had removed the trunking and airflow meter before I got involved!
Thanks again, best regards, see you at the LMC AGM???
Leo
Leo
leo capaldi
LMC AGM
Hello again Pol,
I just replied to your message via email, but earlier I asked if you were in Scotland but it looks like you are in Belgium.
Anyway, the LMC AGM is a fantastic opportunity to wear your best anorak and talk Lancia. Its the Lancia Motor Club Annual general meeting and its this weekend 11/12th July near Oxford in England.
Best regards, Leo
Best regards, Leo
