S1 clutch disc thickness
lancia7550
Unread post by lancia7550 »
Hi,
I have removed the gearbox from my S1 Rallye 1.3S due to an oil leak from the selector shaft bush.
I am checking all components while I have the opportunity and was wondering if anyone can tell me what the thickness of the clutch disc should be when new.
Thanks,
Albert
racing
Re: S1 clutch disc thickness
Unread post by racing »
This is not easy to say because it depends on the supplier.
If you removed the gearbox use an new clutch disc.
Estimate of the thickness is 7,8 mm ( new )
Regards Andreas
Ed Levin
Unread post by Ed Levin »
The DT doesn't specify the thickness when new, just the minimum (replacemen)] thickness of 6.2 mm.
racing
Yes, can be .But i have had a look on the drawing of the disc.
regards Andreas
Ed Levin
I wasn't contradicting you. If the replacement thickness is 6.2mm, then I'd expect the thickness when new to be around 1.5mm more. That actually confirms your measurement of 7.8mm
racing
I know. Everything is o.k..
regards
lancia7550
Thanks guys.
hufo
Unread post by hufo »
Where do you buy the clutch disc?
I need also one for my Fulvia Rally S1
Return to “65 Fulvia”
