Hi,
I have removed the gearbox from my S1 Rallye 1.3S due to an oil leak from the selector shaft bush.
I am checking all components while I have the opportunity and was wondering if anyone can tell me what the thickness of the clutch disc should be when new.
Thanks,
Albert
S1 clutch disc thickness
Re: S1 clutch disc thickness
This is not easy to say because it depends on the supplier.
If you removed the gearbox use an new clutch disc.
Estimate of the thickness is 7,8 mm ( new )
Regards Andreas
Regards Andreas
The DT doesn't specify the thickness when new, just the minimum (replacemen)] thickness of 6.2 mm.
Yes, can be .But i have had a look on the drawing of the disc.
regards Andreas
regards Andreas
I wasn't contradicting you. If the replacement thickness is 6.2mm, then I'd expect the thickness when new to be around 1.5mm more. That actually confirms your measurement of 7.8mm
I know. Everything is o.k..
regards
regards
Where do you buy the clutch disc?
I need also one for my Fulvia Rally S1
- 426698_618080234869431_1569379861_n.jpg (112.9 KiB) Viewed 976 times
