1600 HF Timing Chain Tensioner
Re: 1600 HF Timing Chain Tensioner
i have seen this type of bushing before, mostly used to correct any difference in bearing sizes. not a good solution IMHO. just hardening a new pin is only part of the answer. you also need some sort of bearing surface as well. i might suggest boring the arm and pressing in a bronze busing as well.
'67 fulvia sport, '61 appia vignale
second try not received.
look at Fulvia register running nr. 19 with new end @zf.com instead sachs.de.
regards
Andreas
regards
Andreas
lanciagarage
Hi andreas, I don't know why your messages are not getting to you. I will try a "test" one again.
Please give me that site address again, I can't work out what you put in the post.
Regards
Phil
Regards
Phil
lanciagarage
Hi Andreas,
I'll send you a mail later in the week when I get a chance.
Regards
Phil
Regards
Phil
