Huib Wrote:
> Did you connect the wire for the rev counter to
> the wire coming from the points or to the -
> (minus) terminal of the coil?
> I offer an electronic distributor on this site.
> See
> http://www.viva-lancia.com/specials/ignition/index
> .htm.
> The rev counter works with it.
I have tried all different combinations of wiring, the rev counter (Veglia, berlina) needle will jump a little but not register the revs. I can't afford a new distributor. Could there be a fault with the ignition amplifier in the Sparkrite? I have tried another (Yazaki) rev counter and it does the same thing, very low erratic readings when switched on to the electronic setting but works on the points setting.
Adjusting Jaeger speedometer
Andrea Nistri
Re: Electronic Veglia rev counter
Unusual as I fitted a Sparkrite electronic module to my Fulvia S2 in 1986 and everything works fine ever since. However, I have Jaeger instruments: can you borrow a Jaeger rev counter and see what happens? Andrea
Andrea N.
Re: Adjusting Jaeger speedometer
Evidently my Jaeger Speedo is different from yours. While mine has a screw in the back, adjusting it achieves nothing. My Speedo continues to read high (80kmh displayed at 60kmh verified by my gps speed app).
