pic one shows the shell after preparation and a zinc dip to high standards,note this chassis has a genuine abarth plate kit and cage gravel spec inc pressed turret tops,sills,engine bay legs plated,seam welded,all major joints have extensive structural reinforcement
pic 2 car at a shakedown
quick spec
ex wrc carbon seats,sabelt 6 point harness,stack dash display,52mm stack egt lamda,boost,temp,bbm engine oversize headbolts,uprated internals and flowed head,turbo technics 360 turbo,one off tubular manifold,double spring coilovers with helpers,group a top mounts,forest spec 4 pot brake kit,glass removed perspex fitted,carbon wrc handbrake,bias adjust,a&h alloy big core rad,alloy oil cooler and oversize intercooler,ah fuel cell,atl gauge and filler,carbon boot,bonnet,front wings + more
work in progress.
delta rally car build
- hf.jpg (125.27 KiB) Viewed 858 times
- img_1696.jpg (133.77 KiB) Viewed 858 times
Re: delta rally car build
abarth rear turret plate and cage after zinc dip
- img_1700.jpg (140.04 KiB) Viewed 858 times
painted and prepped by john brain then moved to tanc barratt
- img_17447.jpg (157.9 KiB) Viewed 858 times
engine bay,note the chassis leg plate and turret top.roll cage attaches to the turret tops
- img_1738.jpg (156.68 KiB) Viewed 858 times
- img_1712.jpg (146.93 KiB) Viewed 858 times
goodwood festival of speed 2010 richard burns foundation display
attracted a lot of attention as a "work in progress"
to promote on this vehicle email roughcutflex@gmail.com
ffi and to help the cause go to www.richardburnsfoundation.com
for preparation of your lancia email me rc developments at the above address
- screenshot_3.jpg (159.18 KiB) Viewed 858 times
- img_0601.jpg (167.59 KiB) Viewed 858 times
