Hi all,
I bought a used Thesis (V6 3.0 / 2003) near 100.000 km and I am facing several troubles probably related to Electronic.
They can be set in four categories. I don't know if the are related to the same problem or not.
1) Some times, instead of having display of mileages (partial and total) on the dashboard, I got "EOL Error" blinking (EOL instead of the partial display and Error instead of the total display). To reset, I need to stop/start the engine, sometimes it's reset, some times not. I don't know what is the meaning of "EOL Error".
2) From times to times, the radio stop automatically. Then the clock and external temperature display desappear on the dashboard. The buttons on the steering wheel don't work. When I stop the engine, the radio don't stop, I need to stop it manually. This trouble reset automatically after a period from few minutes to more than one hour.
3) The Air conditioning stops automatically it self . IE The display turns off completely and cooling stops too. To reset, I need to start the radio ???? .... No, I am not drunk.
4) From time to time, I got alarm messages on the dashboad such as "EPB" "COMFORTRONIC" "ESP" .... asking me (in french language) to go to the "atelier".
If some one in the LANCIA world has an idea,
Except that, I am very happy with this car.
Sorry, I don't speak german, but replies in english or french languages are welcome.
Many thanks in advance.
THESIS V6 3.0 2003 : Strange Electronic troubles.
Pierre VALLADE
Aurelia B21, Flaminia GTL, Flavia Milleotto, 2000 coupé,
Beta HPE, Beta Trevi VX, Prisma 1.6, Kappa coupés 2.4 & T20, Thesis V6 3.0
Re: THESIS V6 3.0 2003 : Strange Electronic troubles.
Hallo Pierre
Nr 1,2,3, Hebben te maken met je verbinding, van het Connect kun je laten repareren in Torino Italie bij TSW
Je Kunt geen Betere firma vinden, mij heeft het zoeken een jaar gekost.
Maar een nieuw kost ook meer als 4000 euro!
Het heeft mij daar 250 euro gekost dus dat is een ander bedrag.
Je Kunt proberen hulp te Krijgen van Rino (hier ook op het forum) ivm de taal.
Hij heeft al meer Thesis Rijders geholpen.
Nr 4 als je er verder geen belemmering van hebt, fijn van je auto genieten!
Groet Eric Maasbracht NL.
THESIS V6 3,0 2002.
THESIS V6 3,0 2002.
For the 4 problem, clear this connection
- abs_unit.jpg (105.79 KiB) Viewed 902 times
I guess you meant to clean the contacts of the connection.....
Gruss.....Starbiker
Hi Pierre!
You must take the conector off (giorgios picture) and just use the contact spray. If that dosnt work you must get the software and just reset all the inputs in the main computer. That is work for a mechanik.
All the best
Marcel
All the best
Marcel
Pierre
Aan al deze onzin heb je dus niets!
eol error heeft alleen met het connect te maken !
GR Eric
GR Eric
salut Pierre,
comme déjà annoncé par Eric il faut laisser faire une analyse totale de la système Connect. ça ne te coûtera que 250,- euro pour la seule solution impeccable.
Si tu veut je te peux aider avec la procedure dans n'importe pas quelle langue français, anglais, italien, neérlandais, allemand.
L'expérience de Eric est ce que tu peux que perdre du temps et surtout de l'argent avec tous les autres conseils.
A toi le choix.
Salutations, Rino
A toi le choix.
Salutations, Rino
