1600 HF Timing Chain Tensioner
CD's with documentationElectronic distributor
lanciagarage
Unread post by lanciagarage »
Does anyone know what the purpose of the corrugated bush in the arm of the 1600Hf tensioner is? This bush is not present in the 100 tensioners?
Phil Laing
Cape Lancia Club - South Africa
www.lancia.za.org
racing
Re: 1600 HF Timing Chain Tensioner
Unread post by racing »
what do you mean with "corrugated bush"
If you mean the grooves I would like to say reduce friction and to catch oil
for chain lubrication.
regards Andreas
lanciagarage
Hi Andreas, if you remove the arm (Not the shoe) from the main mechanism by removing the circlip, the arm slides off the pin and inside is a corrugated bush. This is what I am talking about
Phil Laing
www.lancia.za.org
lanciagarage
Hi again Andreas, I sent you a private message about this a few days ago. Maybe you have time to read it and respond.
Thanks
Phil
www.lancia.za.org
Phil Laing
www.lancia.za.org
ncundy
Unread post by ncundy »
This 'orrible little thing ? I have the same question. Mine is worn through.
racing
Hi Phil,
i didn´t receive an message from you. Maybe you mean an other " Andreas". If not try it again.
regards Andreas
PS.: I will look end of the week after this corrugated bush ( as i see now by neil´s mail ) at home.
lanciagarage
Yip that's the little bugger! I also notice that all the 1600 tensioners I have stripped (well ony 2 so far) have a lot of play on the shaft between the bracket of the shoe. I have discovered that by using a 1300 arm (without that 'orrible little thing) that there is no or extremely little play. So I think that's the route I'm going to take.
Phil Laing
www.lancia.za.org
lanciagarage
Hi, I did send it to you, I have sent another one....................Huib Help!!!! is sometyhing not working?8-)
Phil Laing
www.lancia.za.org
lancialulu
Unread post by lancialulu »
Looks like the remnants of a needle roller bearing.
Huib do you know of this as a problem?
Tim
ncundy
It looks a bit like that I grant, but it isn't. It is just a piece of corrugated stainles steel that is bent round the pin and the arm is pushed over the top. When new I imagine it has just enough spring in it to offer some sort of control to the orientation of the tensioner. But because it is very thin (and not very accurate) it distorts, and because it only wears at the point it touches the bore in the tensioner arm (ie very locally) they are a very loose fit. Also the pin is not hardened so they wear as well. The tensioner on mine rattled around like a bean in a tin. I haven't thought about how to do it yet, but the 1300 route is a good option (thanks Phil) - as is making a new pin up and getting it hardened.
It's all a bit crude, as I think Phil can attest.
Return to “65 Fulvia”
