hi,
í heard about ICS with 13pin connector And pressing TRIP for 3sec..
My ICS has no connector ( only the hole and solder pins for it ) and it doesn´t switch to the scond input by pressing the TRIP button. perhaps you must upgrade the ICS Firmware. ????
I have done the switching with the LOUD-button and with a little circuit . ( The loud button is not used with BOSE system).
Sorry this is all the ionformation i have for you,
PS: Do you have the pin description from the 13pin Connector? How is the Navi Sound connected?
Bye
Viva Lancia
CarPC Project im Lybra mit ICS
Re: CarPC Project im Lybra mit ICS
Hi Klaus,
Thanks for the quick reply. I will see and search for the solution and keep you and the forum informed on my progress.
I dont have the the pin description from the 13pin Connector. Sound of the nav is done via the phone in and the mute function.
Cheers,
Xander
Cheers,
Xander
Re: CarPC Project im Lybra mit ICS --- > Daniela
deine email fkt. immer noch nicht. 550- User unkown.
Wenn ich jedesmal die Antwort hier reinschreibe dann, hilft es den anderen auch nicht weiter weil je aus dem Kontext gerissen ist.
Bitte überprüfe mal deine email.Konfiguration.
Danke
Danke
Steht das Projekt, oder ist es vollendet??
