s1 Fulvia A-arm bushings.
CD's with documentationElectronic distributor
Peter
Re: s1 Fulvia A-arm bushings.
Unread post by Peter »
>I would suggest that 185-70/14s are a bit large - you will be over-geared too.
Paul, I fitted a 11/43 diff for that reason.
Paul de Raymond Leclercq
Unread post by Paul de Raymond Leclercq »
Well, that solves that one then!
Paul
Tony Kovacevic
Unread post by Tony Kovacevic »
Dan, When I had My workshop I converted over 40 Fulvia lower a arms (my own Fulvias included) using "Nolathene" poly bush kits supplied by Lambda Motors in Mittagong Australia. They work a treat. I have also used original Ser2 bushes but the poly bushes are better. They firm up the ride nicely and certainly improve the handling.
Tonyk
Manuel
Unread post by Manuel »
Do you have an idea how much they cost ?
Best regards,
Manuel.
> Tonyk
Yes please let us know.
Paul
Tony Kovacevic
Would you believe my suppliers are on holiday in Europe at the moment. I will endeavour to obtain current prices for the bushes and conversion kit as soon as they return to Australia and then post a response.
rgds
Tony
Return to “65 Fulvia”
