how to Adjust Series one column gearchange
CD's with documentationElectronic distributor
fay66
Unread post by fay66 »
Can anyone help please with how to adjust the column gearchange on series 1 GT Berlina for a friend in Australia, he can't get first and second gear, and working out how it all works is a bit difficult.
The workshop manual isn't much help I'm afraid
Brian.
Jean de Barsy
Re: how to Adjust Series one column gearchange
Unread post by Jean de Barsy »
It's probably due to worn plastic caps. Check the rods and you will see there are plastic "cups" you can tighten to take out the play.
If there's play, it will not work properly.
Huib
Site Admin
Unread post by Huib »
Jean is right. There are some plastic parts (cups, washers) in the system. The plastic from the 60's is much less stable than todays plastics. The parts will crumble or already have. Replace all the plastic parts and you have a different gear change
Return to “65 Fulvia”
