Fuel and brake line
Fuel and brake line
Looking for pictures of the fuel and brake line attachment points along the passenger side under the rocker for a 1963 Lancia Flavia convertible. Thanks
lucasgeheniau
Re: Fuel and brake line
Perhaps in the partsbook, DVD available on this website
I don't have a picture available right now but it's a quite simple to describe; both piping are routed together in the internal slot aside the passenger rocker (so in order to be partially protected); they are hold every about ~250mm by ~10mm iron folded stripes soldered to the body.
Can you send me a sketch of the internal slot? Is the internal slot part of the floor pan as shown on attached picture?
- brake_fuel_line.jpg (35.33 KiB) Viewed 1589 times
Does the attached picture show the correct fuel/brake line routing? Circles indicate where the metal hold down straps are located.
- brake_fuel_line1.jpg (39.23 KiB) Viewed 1589 times
Hello,
I don't know if this will help, but this is how they are routed in Flavia Milleotto:
https://onedrive.live.com/redir?resid=5 ... =folder%2c
Have you sorted that problem in the meantime? If not I could take photos of my convertibile.
Hubert
Hubert
Hubert
Hubert,
I am all set. The information that the guys sent me was enough to get it right.
Thanks,
Brian
Thanks,
Brian
