Flavia trunk repair
Flavia trunk repair
Hi,
Does anyone have detailed pictures of the Lancia Flavia Convertible trunk construction that includes the rear cross beam (adjacent to trunk latch) and the structural sections that tie into it. Also the trunk floor outer edge adjacent to the rear fender.
Thanks,
Brian
Thanks,
Brian
- capture.jpg (172.55 KiB) Viewed 1690 times
Re: Flavia trunk repair
Hi bmw8890, try to take a look of the following pictures set:
https://www.flickr.com/photos/108595436 ... 736374754/
Those picture have been a great help but I am trying to get more detail of the beam section of the trunk adjacent to the fenders. The pictures clearly show a beam/stiffener but I need to see the under side to figure it out
Hi,
please find attached a couple of picture of trunk right side zone of my car, with an upper upper and bottom view.
I hope can help you, if you need to magnify some details please mark it in the picture and I'll try to do a better shot.
- img_20150926_081936.jpg (187.03 KiB) Viewed 1689 times
- img_20150926_081639.jpg (189.17 KiB) Viewed 1689 times
.. just another picture
- img_20150926_121734.jpg (195.75 KiB) Viewed 1689 times
Can you send a pictures of the other side of both inside and underside? Thanks for the pictures that you sent.
left side, here they are....ciao.
- img_20150926_165903.jpg (197.24 KiB) Viewed 1689 times
- img_20150926_170238.jpg (193.8 KiB) Viewed 1689 times
looking for a picture under the trunk of the wall that attaches to the fender as shown in the attached file. Not sure how it attaches to the back section of the trunk rear support.
Thanks,
brian
Thanks,
brian
- capture.jpg (90.96 KiB) Viewed 1689 times
Ciao Brian, the fender is attached in the support upper side by the brackets and bolts visible in the pictures I've alredy posted here; from the bottom you can't see anythings.
