check warning when driving fast
HF
When my speed is between 180 km/h and 190 km/h the red checklight on my dash goes on and the oil warning light in the check panel goes on. At 190+ the "problem" is gone. Does anyone has a clue what the cause is and how to fix it?
Chris Moorey
Re: check warning when driving fast
It could just be poor connections on the oil sender or earthing or dirty oil at the sender end. Check and clean everything. The check panel is ultra-sensitive. for example a very slight drop in radiator level will activate a signal of no water !HF wrote:
