check warning when driving fast
HF
Unread post by HF »
When my speed is between 180 km/h and 190 km/h the red checklight on my dash goes on and the oil warning light in the check panel goes on. At 190+ the "problem" is gone. Does anyone has a clue what the cause is and how to fix it?
Chris Moorey
Re: check warning when driving fast
Unread post by Chris Moorey »
It could just be poor connections on the oil sender or earthing or dirty oil at the sender end. Check and clean everything. The check panel is ultra-sensitive. for example a very slight drop in radiator level will activate a signal of no water !HF wrote:
Return to “51 Thema”
