beg your pardon, i hope this is the correct word for this part.
now there are very good news. a new switch shift is possible to order.
this part is running in test-time by a beta spider driver.
we never have it to change it. --wartungsfrei--
delivery is possibel mid january.
costs are in calculation.
send your old part and get back --restored.--
beta driver
hpe ie
delta 2
schaltgestänge--switch-shift
Re: schaltgestänge--switch-shift
Unread post by jw »
Hi Mikele
I cannot get the gear into 5th or reverse while 1 through 4 is fine. Something wrong with the vertical rod which is connected to the gearbox on one hand and to the shift rod on the other. Seems that a plastic O-ring is missing (see also posting on Lancai-beta.de forum in Oct).
Are you offering a solution for my problem or are you referring to something else?
Thks/br, JW
(Spider 2000, NL)
Thks/br, JW
(Spider 2000, NL)
Unread post by jw »
see also posting 5 sep 04 right here below in this forum section
Return to “61 Beta, Beta spider, Beta Zagato, Trevi”
