Hi,
I just worked out my previous problem on the spider. But now i seem to have another problem. When i put the direction finders on (indicators) they seem to flash very quickly, almost continuously, instead of the, click......click.......click, im getting a click.click.click. The problem arises that the light losses power and can hardly be seen my other motorists. I have a feeling that maybe too much current is passing through the solenoid that controls this. As when i put the Hazard lights on, ie, when both indicators flicker at one time, the timing is perfect and i get the appropriate, click.....click.......click. How cani fix this problem?
Hope you guys can help AGAIN!
Many thanks in advance, you truly are saints.
Iterval on Indicator- Beta Spider
Re: Iterval on Indicator- Beta Spider
Unread post by Mathias Vandelanotte »
I've had the same problem, but it was because the frontbumper of my beta wasn't on the car (so the signal lights were disconnected). Maybe there is a wire not connected, I don't think there is something broken that is very difficult to fix
Return to “61 Beta, Beta spider, Beta Zagato, Trevi”
