Please, if you know send me informations about:
1. tyre dimensions
2. scheme of braking system
3. gearbox specifications
THANK YOU!!
Lancia beta HPE tyre dimension
leo capaldi
Re: Lancia beta HPE tyre dimension
What version of HPE is this about?
My standard 1983 car has alloy wheels and uses 185/65 x 14 tyres. I beleive that the steel wheels had 175/70 x 14 tyres.
The gear ratios do not vary much and tend to be:
1st 3.5
2nd 2.235
3rd 1.522
4th 1,152
5th 0.925
Rev 3.071
Final drive ratios:
1300 15/67
1600 14/57
2000 14/53
VX 3.263:1 (14/46?)
The front brake calipers have two cylinders and the pipes make up two circuits - so each circuit feeds both front calipers and one rear. There is a proportioning valve that reduces the pressure to the rear calipers if there is no weight in the back (passengers or load).
Can send you a diagram - will have to scan it or draw it though.
Leo
1st 3.5
2nd 2.235
3rd 1.522
4th 1,152
5th 0.925
Rev 3.071
Final drive ratios:
1300 15/67
1600 14/57
2000 14/53
VX 3.263:1 (14/46?)
Leo
hrvoje
leo, thank you for this info.
diagram would be great, and please, send me it if you have time.
hrvoje
hrvoje
leo capaldi
Re: Lancia beta HPE tyre dimension and braking system
Hello again,
Took me a while but I have uploaded a brake system diagram to http://www.lancia.fsnet.co.uk/images/beta_brakes_1.jpg
This is from the Haynes Beta W/shop manual. The scan was not quite straight but I'm sure that it will be good enough for you.
Good luck, Leo
Good luck, Leo
