what rims for my S 1 ?
georges2
Unread post by georges2 »
I am the happy owner of a S1 coupe Rallye S type 818360 issued november 1970 (late S1 which I beleive were already fitted with the 818303 engine)
it is fitted with steel rims stamped 6J14 (which have given normal service for years...)
As I would be pleased to fit alloy rims, I wander if I choose 13 ou 14 inches rims, as I beleive the normal S1 coupe cars were fitted with 13 inches rims
Can anyone give informations about the standard fittment ?
Thanks
josefHF
Re: what rims for my S 1 ?
Unread post by josefHF »
hello georges-the standard rims for S 1 cars are 4,5x14 the 13 inch rims are only for the S 1 HF 1,6 fanalone-If you want to use them you will get troubles with the brakes or You use spacers-regards josef
georges2
Thank you Joseph, now it's clear I know what to do for my car.
However, and just for increasing my knowledge, I understand that the 13 inches rims are not suitable with the standards breaks (Dunlop) on S 1 coupés
So do you know if this means there were different break models on 1300 HF ?
and also about rims and tyres, as 13 inches rims are smaller, the circumference is shorter, with effect on the speedometer ?
Best regards
Ed Levin
Unread post by Ed Levin »
Of the S1 cars, only the Fanalone came with 13" alloys (6 x 13); all of the others came on steel 4.5 x 14. But the brake calipers are the same for all S1, so 13" wheels will fit on any S1. The biggest problem is the width; over 5.5" wide, the tires can rub the wheel arches, unless you're using smaller diameter race tires.
But to your real question--whether to go with 13" or 14" alloys--I'd suggest going with 14", as it's much easier to get tires in 14" these days. It is very tough to find good tires in 13" in the correct height.
Huib
Site Admin
Unread post by Huib »
The S1 (any in fact) Fulvia runs best on the original steel wheels with the original tyre size. Bridgestone makes an excellent 145/80R14 tire. It has to be inflated to a somewhat higher than usual pressure. I use 2.2 to 2.4 bar.
If you insist on changing to 13" rims you can use 165/80R13 tyres. Plenty of good tyres are available in this size. The circumference is the same as for the 145R14.
With some types of the 13" wheels you will have interference with the brake callipers and the pincher of the handbrake. This can be solved by grinding some off the callipers. Also make sure there is clearance between the brake lines and the wheels.
At the rear you will also have interference with the wheel arches. When you use the Stilauto 5,5J13 wheels with 165/80R13 tyres you have to extend the rubber stop over the rear axle by 45 mm. I also advise stronger rear springs. With the standard springs the rear axle will hit the stop all the time which shortens the life time of mechanical parts such as the wheel bearings and body. If you use 6J13 wheels, you will have to extend the rubber stop even more.
Ed Levin
Huib's quite right about being able to find correct tire sizes for 13" tf you're trying to match the original 145/80-14. 165/80-13 is just slightly (3.5mm) taller than the original, but that's mostly within margin of error. (My comments about it being difficut to find appropriate 13" tires reflects the fact that in my case I'm trying to match an original tire size of 175/80-13, and that size is virtually impossible to find)
But Huib's also completely right that the original wheel/tire size is generally the best for road use. Wider wheels/lower profile tires will add some lateral grip, but not enough to make up for the loss of delicacy and crispness in the steering feel. IMHO.
ekranoplan
Unread post by ekranoplan »
Some S1 Zagato cars had 13" steel rims and several 1.3HF's raced with these.
Check the ET (offset) before fitting - you may not need spacers. Huib is correct the Fanalone wheels will fit S1 rear Dunlop brakes but the handbrake calipers get in the way - 1.6HF had modified arms.
I use 185/60R13 on my racing 1.6HF and can go to 205/60R13 but you need Gp4 wheel arch extensions as these can get very tight on the front during steering.
If you have money to burn then Campagnolo rims came in 13" 5.5J and 6J as well as 14"
Huib is also right about the 145/80R14 tyres - these are std fit on my 100mpg Audi A2 1.2 TDI and I have a set for the Fulvia when driving to race tracks!
Above all enjoy your car!
Ed Levin
185/60R13s will change the effective gearing, as they're much smaller diameter than the original 175/70R13s. Fine for racing, but not so good for the street.
georges2
Many thanks to you all for these informations and recommandations
As my car is regularly fitted with 14 inches new tyres, I would like to find 14" rims
A few monthes ago, I found an information about new made rims on an US website (Mr Fiat I think)
It was described as this : (and see picture attached)
NEW - CROMODORA CD 28 ALLOY ROAD WHEEL. 6 X 14", 4 X 130 MM BOLT PATTERN, 23 MM OFFSET, WEIGHS 6 KILOS. SPECIFY SILVER OR GOLD WHEN ORDERING! we are glad to inform you we can supply the Cromodora CD28 aluminium replica for Lancia Fulvia. Size 6x14, pcd 4x130, ET 22,5, weight 6,5 kg. finish: silver. Conical bolts 14x1.5 mm, chromed center cap. 100% made in Italy, with accessories. IF OUT OF STOCK THIS ITEM CAN BE RESTOCKED FROM ITALY IN 4-8 WEEKS. TO MAKE SURE WE GET ONE FOR YOU PLEASE FILL OUT & RETURN THE SPECIAL ORDER FORM FOUNDHERE, PLUS INCOMING FREIGHT & US CUSTOMS CLEARANCE CHARGES.
This product was said to fit S1, another model is for S2-3
I was informed that after order, the rims would come to me directly from Italy to France....so I asked about the firm that really made these rims
And I tryed to find a seller in Italy or here in France, but could not find anyone
So I decided not to order
If one of you have any informations about these products, I would be happy to hear what you think
Thanks again
Georges
cromodora cd28.jpg (14.19 KiB) Viewed 4326 times
gamma a.i.
Unread post by gamma a.i. »
scroll back to earlier posts; these wheels have been discussed in the forum previously
Return to “65 Fulvia”
