Hi All,
I've found a Beta Spyder local to me in sunny Aberdeenshire which is probably going to be split for parts - I haven't looked at it too closely but if you need parts drop me an email or better still call me on 013398 85530
I would hate to see it scrapped before any useful parts come off it.
I'll post a note on it's general condition after I've given it a closer inspection.
Cheers Hamish
Found! - Beta Spyder
Hamish
Re: Found! - Beta Spyder
The Spyder has 'gone back to nature' in a big way but the the rear bumper and many trim parts are all in excellent order - can anyone use it??
paul wedgbury
HI HAMISH,
I"VE JUST BOUGHT A LANCIA BETA SPYDER WITH SLIGHT ACCIDENT DAMAGE & NEED THE FOLLOWING PARTS.
DEFINATELY NEED ASAP: O/S HEADLIGHTS
O/S FRONT WING
O/S FRONT INDICATOR
MOUNTING BRACKET BEHIND
O/S HEADLIGHT.
GLOVE BOX LOCKING CATCH
MAY CONSIDER IF CHEAP:FRONT BUMPER
FRONT PANEL
CHEERS PAUL
TEL.07775606385 OR 01625502372 WORK
O/S FRONT WING
O/S FRONT INDICATOR
O/S HEADLIGHT.
FRONT PANEL
CHEERS PAUL
paul wedgbury
HI HAMISH,
O/S FRONT WING
O/S FRONT INDICATOR
O/S HEADLIGHT.
FRONT PANEL
CHEERS PAUL
O/S FRONT WING
O/S FRONT INDICATOR
O/S HEADLIGHT.
FRONT PANEL
CHEERS PAUL
Hamish
Paul,
Can't help with body parts - believe me this one has gone back to nature in the biggest way!
Might be able to help with lights - do you mean the light mounting bracket? If so which series is your car?
Front bumper and rear bumper available.
Email me for info
Hamish
Email me for info
Hamish
alan cooper
except for the wing all of these parts will be the same as the equivalent coupe series so you shouldn't have too much trouble searching them out.The front wings on spiders are modified as spiders have a different sill structure presumably to add strength and this means that the bottom of the wing is different; on spider wings the bottom is removed and a stepped out piece is added to the bottom which follows the sill line, the step out is partially disguised by the black plastic trim strip below the doors along the sill.
paul wedgbury
HAMISH,
I"ve emailed you some photos of my car to your own mail address.
regards Paul Wedgbury.
paul wedgbury
ANYONE WHO WANTS TO SEE SOME PHOTOS OF THE LANCIA BETA SPYDER WHICH I REQUIRE PARTS FOR CAN SEE THEM ON THE PARTS WANTED SECTION OF THIS SITE OR THE CARS FOR SALE SECTION.
REGARDS PAUL WEDGBURY
