I'm going to have my block rebored and sleeved, the pistons appear to be fine, I would however like to replace the rings but unfortunately
I am unable to source them locally, are there "compatible" rings that can be used? Thanks.
						Block, piston rings
				lancialulu
Re: Block, piston rings
Believe Omicron will have standard rings. They do excellent shipping.
Tim
						Tim
I'm sure Tim's right that Omicron will have standard rings.
But if you haven't already done so, you'll want to measure the pistons, to confirm the ring size you're looking for. I wouldn't assume the pistons are standard bore. And I apologize in advance if that sounds much too obvious.
Thanks Tim, will give them a try..
Ed: You are of course correct... never assume anything! I however am sure they are standard.
