Electronic Ignition also available for 1600
Huib Geurink
Unread post by Huib Geurink »
Finally the bushes to adapt the unit for 1600 have been made. An aluminium bush to increase the diameter of the shaft to fit the hole in the 1600 heads and a steel bush to convert the 10 mm spindle to 12mm for the 1600 gear wheel.
I also had plug wires made from high quality 8 mm silicon cable with stainless steel contacts, 90 degree terminals on the cap. The wires carry the numbers 1 through 4 on both ends and can be used on series 1 and series two with this electronic ignition and with the original ignition.
The picture below shows the unit with the cables.
Prices are:
ignition unit: 269 euro
conversion kit for 1600 engines: 15 euro
red 1.5 Ohm coil made by Beru: 42 euro
the black coil is no longer supported
set of plug wires: 75 euro
Note that the prices are excl VAT. For delivery inside Europe 19% VAT is added unless you provide me with a valid VAT number.
15 euro postage for ignition inside europe
25 euro postage for ignition outside europe
25 euro postage for ignition plus coil inside europe
40 euro postage for ignition plus coil outside europe
postage for plug wires is zero if included with ignition.
See also http://www.viva-lancia.com/lancia_fora/ ... amp;t=4575
LFW
Re: Electronic Ignition also available for 1600
Unread post by LFW »
Well done Huib!
Anyone have a spare 1600 dizzy gear cog to go with one of these?
Tom Callanan
Unread post by Tom Callanan »
Huib,can you pl contact Peter Geraghty Who prepares my car : 00 353 87 2560356. We would like to order a distibutor as per your e mail and he is not able to contact you. Tom Callanan,Dublin.Huib Geurink wrote:
> Prices are:
> src="http://www.viva-lancia.com/lancia_fora/ ... cables.jpg">
> See also
> http://www.viva-lancia.com/lancia_fora/ ... 575&t=4575
Return to “65 Fulvia”
