replace ignition coil
folka
Unread post by folka »
Hola a todos.
I have to replace the old MagnetMarelli BES200A ignition coil.
Do you know types by other brands which fit to a 1975 1,3s Coupe, please
(for a better chance to find one here in canary islands)?
Many thanks,
Volker
Huib
Site Admin
Re: replace ignition coil
Unread post by Huib »
The widely used replacement coil is the so called "Blue Bosch coil" made by Bosch itself of course and also by Beru. The resistance of the primary is about 3,3 Ohm. It should be used without ballast resistor as any coil with a resistance greater than 3 Ohm
lancialulu
Unread post by lancialulu »
Lucas Sport coils also work well. You could use ebay of course....
Tim
folka
Hola Huib and Tim,
many thanks for helping.
Saludos, Volker
Return to “65 Fulvia”
