How to adjust door lock?
Michael Beattie
Unread post by Michael Beattie »
Can anyone tell me how to adjust the door lock on a coupe? One of the doors on my car requires a rather firm push to get it fully closed, yet the other closes quite easily.
The lock is lining up perfectly and hasn't fallen down at the closing edge. So it is just any outward or inward adjustment of the lock or the keeper I need to know how to do.
Cheers
Michael
Huib Geurink
Re: How to adjust door lock?
Unread post by Huib Geurink »
Is it S1 or S2? Alu doors or steel? Any difference if window is open or closed?
Michael Beattie
Huib
S2 steel doors. Hard to close even with window open.
Michael
neil
Unread post by neil »
Is the quarter light frame hitting the seal at the top before the door is closed ?
Is the locking mechanism (either the lip on the underside of the female, or the profile of the latch in the lock) worn.
Mine would not close easily for both these reasons and I had to adjust the frame and replace the lock.
Walter van Gruythuysen
Unread post by Walter van Gruythuysen »
I had more or less the same. It turned out that the bolts fixing the 'catch-part' to the car were not tight enough. Very easy to check.
Walter
Michael Beattie
Problem sort by moving the frame catch plate.
Bobskifiat
Unread post by Bobskifiat »
Huib Geurink wrote: 01 Sep 2008, 09:24 Is it S1 or S2? Alu doors or steel? Any difference if window is open or closed?
Hi Huib, I appreciate it's been a while since you posted that reply, however taking a chance you may spot my reply - My passenger door shuts a lot easier with the window down (open) otherwise, it takes several slams... I've been checking rubbers and lubricating and cleaning as much as possible.
I'm concerned that one slam will break the window or locking mechanism completely. I tried repositioning the strike, but so far nothing has helped.
Bobskifiat
Huib it's S2
Bobskifiat
And steel
Huib
Site Admin
Unread post by Huib »
Does it make a difference when the drivers door is open or closed?
Return to “65 Fulvia”
