Coupe S2 1.3S Master Cylinder bore size?
Rick
Unread post by Rick »
Can someone please tell me what is the proper bore. I assume it is 21mm. I understand there are, maybe, 4 different sizes. Is there an issue with using any of the four?
Are the kits readily available?
lancialulu
Re: Coupe S2 1.3S Master Cylinder bore size?
Unread post by lancialulu »
there should be an alloy tag wrapped round the cylinder near the mounting holes which says. Normally 21mm. I think there were 2 othere sizes 17 or 18mm??
Tim
Return to “65 Fulvia”
