Hello,
A pair of new Weber 45 DCOE 152 for sale.
Same basis setup as DCOE 9.
Choke 36 Throttle Plate Angle 78 degrees
Auxiliary Venturi 4.5 Needle Valve 200
Main Jet 145 Pump Jet 45
Air Corrector Jet 155 Pump Spill 40
Emulsion Tube F16 Float Level 12 mm
Idle Jet 55 F8 Starter Jet Fuel 85/F9
Idle Mixture Orifice/Bush 100 Starter Jet Air 150
Progression Holes 120/100/80
550 euro/ pair.
Weber 45 DCOE 152
Michael Beattie
Agusti
Re: Weber 45 DCOE 152
Unread post by Agusti »
Hello Michael,
No, they still have the OEM setup, and it´s exactly the same as the old DCOE 9.
In fact, this is a very good start setup for this engine, but additional tuning will be necessary.
Thank you.
Thank you.
