reading about this 1 off car it states that is it powered by a Lancia 1.8 V4; howver additional research show a flat Lancia motor, dual-carb hidden in the back.
what a lovely after Fulvia Lancia it would have made....but we got Beta'd instead.
too bad the N-B never was built i series !!!!!! 40+ yrs later it is still stunning !!!
http://www.conceptcarz.com/vehicle/z170 ... io-GT.aspx
it could be a Fulvia::o
Re: it could be a Fulvia::o
The description says the engine is a 1.8L Lancia, but doesn't say anything about being a V4--obviously a Flavia unit.
gamma a.i.
tech specs read, as do various texts pertaining to this Gem:
Engine Configuration V
Cylinders 4
another text reads:
initial idea was to use power plant from Flavia V4, but production was ending so several others were tested.
I ask:
Flavia V4 ?
Cylinders 4
another text reads:
I ask:
Flavia V4 ?
it's not even technically a 180 V...
gamma a.i.
I can not remember which car was being referred to...perhaps a Fer BB...but I think I remember remembering reading "this boxer motor is actually a 180° V engine ... or a similar text.
I, of course, had (have) no idea what was meant. I have not lost slip over hit !!!
Ed...now the (roll drums, blow horns) $64ooo question: what do you mean by 180 V ?
As I understand it (which may well be imperfectly), if a 'flat' engine has con rods on separate crank pins it's a 'boxer'; if opposing con rods share the same crank pin, it's technically a 180-deg V.
gamma a.i.
gotcha;) thank you for bringing light to this mystery
