gearbox dropping out of gear
Posted: 10 Sep 2007, 14:46
by william
Hello, Does anyone has experience on resolving the problem I have with my Fulvia 4-speed gearbox were the lever fals down from first after dropping the clutch? As soon as the power is fed to the box the lever has the tendency to fall out of first. I have to hold the lever til the car actually rolls.
Re: gearbox dropping out of gear
Posted: 11 Sep 2007, 20:50
by Huib
What I have seen specifically on first gear which causes dropping out of gear are:
1. bad needle bearing for the 1st gear wheel on the main shaft
2. missing / bad teeth
Posted: 16 Sep 2007, 15:47
by justin
There's a detente spring/ball system on the 5-speed box that is relatively easy to adjust/restore without removing g/box.
Not sure if the 4-spd has similar accessibility, but I bet it does.
PdeRL will know - VAR1016@GMAIL>COM
Regds,
Jus
