Hi all,
Does anyone have a good suggestion for replacement clutch plates? I read that beta volumex (2.0?) would fit? Or some Thema? But these are all 228mm, whereas the gamma is 230mm diameter.
Bart
clutch plate
Re: clutch plate
Unread post by gamma a.i. »
ask this ? on lanciagammaforum.com; you will get a quick & proper reply
Re: clutch plate
Unread post by oldgamma19 »
a Dedra 4 x 4 clutch plate will fit (size 235 which is same as surface of flywheel)
