gearbox swap
carlos
gearbox swap
Unread post by carlos »
hi forum,
How about fitting a 740 gearbox in a 1,3 s S2?
Since the final ratio is the same, any difference in performance?
viva lancia,
Carlos
william
Re: gearbox swap
Unread post by william »
The performance gain is in the closeratio gears. 1st is longer and the rest of the gears fill the space niceley. You won't be disapointed!
When you have the box off. fit a Fiat 1400 uno turbo clutchcover. This clutch is 500gr lighter than the Fulvia S2 clutch (and stronger) Instant swap. Better throttle responce!
P. de R. Leclercq
Re: gearbox swap
Unread post by P. de R. Leclercq »
That's right.
A pity the damned gearbox isn't lighter too!
Paul
william
Re: gearbox swap
No , but at least it is not heavier...
P. de R. Leclercq
Re: gearbox swap
Ha - ha! Good point!
P.
Return to “65 Fulvia”
