Several pics in Enzo Altorios book and repair manual suggest the entire engine, gearbox and subframe can be removed from the car.
I have always removed engine through the top but want to check subframe mounts and continue with rust proofing shell and frame.
What is the best way to do this - 6 big bolts and detatch brakes and steering box?
Cheers
drivetrain removal
ekranoplan
Re: drivetrain removal
Unread post by Huib »
Right. I also remove radiator and obviously you also disconnect wires, hoses, exhaust and shift stick. The subframe is front heavy.
ekranoplan
