transverse leaf spring and graphite powder
Sheldon Laing
Unread post by Sheldon Laing »
I am currently rebuilding the front suspension on a s1 fulvia 1.3 rallye and i have taken the transverse leaf spring apart and cleaned it up. I now have the leaves and the anti-squeaks ready for reassembly but i read in the workshop manual that i should coat the leaves and anti-squeak surfaces with graphite powder. Does anyone know what graphite powder is as i am not familiar with it. Is it some sort of dry lubricant? Is this the correct proceedure or is there something else that can be used to 'lubricate' the leaves?
Thomas
Re: transverse leaf spring and graphite powder
Unread post by Thomas »
Graphite powder is commonly used to lubricate locks, so the tiny internal bits move about easily. It is a very fine grey powder substance (graphite, that is, pure carbon, compress it really hard and you may get a diamond). Try the local lock/key vendor (here in Europe usually associated with shoe-repair shops, don´t ask why).
Neil
Unread post by Neil »
No need to go to these extremes ! Use a lithium based MolyGrease. I have just finished mine and I did the following:
re-pack with moly between all the spring and anti friction leaves
re-assemble and then degrease with white spirit (or similar), remove all excess grease and dry to degrease the exposed surfaces
spray with etch-primer
hand paint with black coach paint (base coat first) - coach paint is thick enough and felxible enough to offer a decent degree of long term protection.
On the rear springs I may wrap them in Denso Tape for a real belt and braces job, but there is not enough clearence around the front spring.
This is standard practice on leaf springs and will do you for a long time.
Return to “65 Fulvia”
