beautiful Fulvia 1.3 Rally s for sale
lanciagarage
Unread post by lanciagarage »
There is an absolutely magnificent RHD Fulvia 1.3 s Rally for sale in South Africa. This car is a two owner car, completely original with only 40000 miles on the clock. Perfect in every way, regularly maintained with a paint restoration and gearbox rebuild 7 years ago.
If anyone is interested, let me know. Price negotiable at Euro 8000. Shipping to Europe aprox Euro 2000
s1 rear view.jpg (161.56 KiB) Viewed 1261 times
s1 front view.jpg (196.83 KiB) Viewed 1261 times
Phil Laing
Cape Lancia Club - South Africa
www.lancia.za.org
mikeg
Re: beautiful Fulvia 1.3 Rally s for sale
Unread post by mikeg »
Phil,
Can you please tell me what those wheeels are on your beautiful Fulvia?
Mike
Ed Levin
Unread post by Ed Levin »
They appear to be the Campys used on early 1.6HFs.
bmarler
Unread post by bmarler »
indeed they are campagnolo. i have the same wheel on my sport. mine are 5.5 x 13. note the 82 mm center caps are very difficult to find. i have been looking for quite some time.
'67 fulvia sport, '61 appia vignale
Ed Levin
They were available in 5J 13, 5.5J 13, or 6J 13 (the last of which was the original homologation wheel for the 1.6HF), and as Brian suggests they were fitted to the Sports as well as the HFs. You can see a better picture here: http://www.alma.it/vanzettip/fulvia/fulviae.html (at upper right, click "mechanics", then "wheels")
Sam Danenberger IV
Unread post by Sam Danenberger IV »
Hello All-
I have set of those Campy's on my Coupe.
I have 3 of the 4 center caps and have been looking for 8 years to find a fourth!!!
The Original Cap is heavy and the Campagnolo logo is CAST in the cap,
not just painted on like the cheap aluminum repros you find here and there.
Please let bmarler or me know if anyone ever comes across any center caps for the 5.5x13 Campy wheel.
I only need ONE!!!
Thanks.
Sam
Lancia-hf
Unread post by Lancia-hf »
the campagnolos fitted to the SA Fulvia are 5.5Jx13. And they suit the car perfectly. I have never seen just a wheel change change the whole appearance of a car so seriousely. With the steel wheels the series one fulvia is almost ladylike in appearance but with just these superb wheels it suddenly becomes mature.I have the same set fitted to my 1200HF as they were a factory option for and also used by the works at the time. The pictures on the Alma site Ed is referring to are not correct as it shows the same picture 4 times with different sizes mentioned with it. As far as I know of only two sizes were made in 13" and they are 5.5 and 6. The difference between the two is as mentioned 0.5" and this can be seen as a 0.5" wide ledge just behind the actual rim. 5jX13 were available in steel.
Sam, there are also two types of centre caps. One type is domed with a 4mm flat edge were a large flat circlip keeps it in place and the other type is a 100% domed cap. To be fixed with a wire type clip.
I might have one lying around of the latter. Let me know.
William.
Sam Danenberger IV
Wiiliam-
I would really appreciate that!
I will check and see which one I have.
I think they are the 100% domed type you describe.
They are beautifully cast, which of course you would expect from Campagnolo!
Ciao!
Sam
bmarler
i have only one cap for my total of six wheels. it is the 100% domed cap. i think sam has a better chance of completeing his set than i! i would be happy to find any caps to fit these, correct or not.
Ed Levin
You might find it's cheaper to have a set made at a machine shop with a 3D scanner and CNC mill than it would be to buy originals, even if you could find them.
Return to “65 Fulvia”
