OK so the engine is back in and running very sweetly.
Except for a breakdown 8 miles from home on Tuesday! It turned out to be the Coil lead was arcing inside the rubber boot!
All cleaned up and works fine again.
Now I have TuV / MoT tomoorow and had no handbrake response.
I thought I could just tighten up the Dunlops (Series 1 Coupe)
Took wheels off and noticed a whole pad was missing!
It had fallen out and just left teh backing plate
All the others have 15mm of material thickness remaining!
QUESTION: Are these pads the same as Jaguar ones or do I need special Fulvia Dunlop pads?
Thanks
Series 1 handbrake pads
Re: Series 1 handbrake pads
Hi,
i don´t know if the they are the same as Jaguar but
normaly every fulvia partdealer have the pads for the handbrake 1.Series.
You have only order them.
regards Andreas
regards Andreas
Peter de Wit
My 15cents on this:
if you have to pass MoT, I would not replace the pads that are in place. Leave those 3 in. And the one you add, best to use a used one. I just went through my collection of stuff to see if I could post you a used one, but I don't have them. Reason for using a used one is that the blocks do not touch the disk perpendicular. A new is straight and will only make contact on the end of the block. I would take the same block from the opposite wheel out, and grind a new one in the same shape (unhealthy), do your MOT and then fit all new hand brake blocks (or not....). I am building a rally car myself and I completely forget about this handbrake. It is very unreliable to block. I managed to get it working in this turn: http://www.youtube.com/watch?v=6YLtxvNE-Jo , but the new one will have hydraulic hand brake only.
