Hi
I have recently acquired a 1989 HF Integrale 8V and will need to change the headlamps as they are currently for UK use and I need European spec, for driving on the right. At least the steering wheel is already on the left.....
My question is:
Are the headlamps for this car also used in other Lancia or Fiat models? Am hoping that they did some parts-sharing.
Not sure @ diameter, but can measure if needed.
Thanks in advance for your advice
Would be interested in buying a set if you have imported an integrale from Europe and have changed your lights to UK specifications.
1989 Integrale LHD Headlamps wanted - shared with other vehicles?
harvestmouse
Return to “57 Delta, Prisma, Delta Integrale”
