strange noise
Katsura Tsukamoto
strange noise
Unread post by Katsura Tsukamoto »
Last Saturday, I attended the Fulvia event and was really enjoy the touring. Then I realized the strange noise from right side of front wheel. The noise was "clonk", and was happened when I made a left turn. It was simultaneous the shifting the load from left to right.
Does anybody have a idea where the noise comes from and what wrong is?
Bart
Re: strange noise
Unread post by Bart »
Did you check your wheel bolts?
Bart
Katsura Tsukamoto
Re: strange noise
Hi Bart,
Actually not yet, but I checked wheel bolts before went to the event. At that moment, it was quite OK. I will check again. Thank you for your comment.
Katsura
Huib Geurink
Re: strange noise
Unread post by Huib Geurink »
Suspension ball joints?
To test the top one you have to take the weight of the car off from the upper wishbone.
To test the bottom one you can use all three of the following conditions:
1. normal, all wheels on the ground
2. jack under the subframe or car body with the wheel off the ground
3. pole under the spring to take the weight of the car, wishbones horizontal
Huib
Return to “65 Fulvia”
