Hello Everyone,
Could someone please help explain the differences between a second series Fulvia 1.3 and a second series Fulvia Rallye 1.3S?
Thanks Alot!
-->Robo
1.3 Series 2 Fulvia vs. Rallye 1.3S Series 2
Paul de R. Leclercq
Re: 1.3 Series 2 Fulvia vs. Rallye 1.3S Series 2
If you are referring only to Fulvia coupes there is no difference because all were called "1.3S" - i.e. they had 818303 engines. All had 31mm carburettor chokes, 9.5/1 compression and 28/66/66/28 cam timing
The only S2 1.3 Fulvias that did not have these engines were the Berlines (818302) engine (9/1 compression, 29mm chokes and 17/65/65/17 timing)
Paul
Paul
Jorn van Beckhoven
Only the series one Fulvia Coupe has different rallye 1,3 and rallye 1,3 S models, the s-model easiest recognisable from the fact that it has a separate oil-cooler next to the radiator!
Brian Hilton
Easy give away is the 1.3s has opening front 1/4 lights, on the 1.3 Rallye they are fixed
