transformation to twin carb in progress
jaro
Hello again... I started the twin carb job last week... I will use two twin solex c35 Pii carbs and all the goodies from an early 1500 coupe...
I have a question about water thermostat housing... it is made of aluminium and is quite corroded... I took the old thermostat out (it is written to be 83 °C) and now I will change all the hoses and use a Renault thermostat instead of the original one... Or can I use a thermostat housing of another car (anyone did this conversion?) ? I also thought of manufacturing a new thermostat housing made of stainless steel or aluminium, but I would rather buy something original ...
Another thing... I read somewhere in this forum that all the waterhoses should be original... Why ? Can t I just buy universal car hotwater hoses ?
Thanks for any reply !
Jaro
Jaro
jean-marie
Re: transformation to twin carb in progress
Hello!
Every spare has his own reason to be there, in a lancia car mare than in others , be very careful,with out-standard spares!
When you search, a Lancia standard thermostat for Flavia costs 10 euros: dont'hesitate.
Regards: jean-marie
Regards: jean-marie
jaro
I would use a standard Lancia thermostat, but my thermostat housing is very corroded and it is impossible to use the original screw-in thermostat... therefore I will use a BEHR 83°C hose thermostat...
...Every spare has his own reason to be there, in a lancia car mare than in others , be very careful,with out-standard spares!...
I am sorry but I really do not understand what you are telling me... Is it that I must use only original spare parts and not the universal (like water-hoses)?
Thanks for your reply !
Jaro
Jaro
Hein Reedijk
I also use a hose thermostat in my flavia (Wahler 3029.83). Works fine. Ofcourse you can use other hoses, if you can find hoses in the right shape.
Best regards, Hein Reedijk.
Bert Ewalds
I run a Flavia Coupe and a Flaminia Convertible
In the Flavia I still have the original thermostat but in the Flaminia the housing is also corroded and I use a hose thermostat (make Waehler)
Off course the original thermostat is wonderful if you can still fit it in the housing, but a hose thermostat of the proper temperature does a perfect job, I already run it for 6 years on the Flaminia.
Advantage of a hose thermostat is that you can easily adapt it to your climate
In Holland I run it on an 85 degree thermostat, but I ran the car over the Alps and in Italy (Tuscany) and I fitted a 75 degree one before the trip.
Bert
Bert
jaro
Hello, the transformation is finished !!! The car has more power and feels very nervous... it shakes all over the place... the sound from 2 double carbs is something sensational... I have one more question... I will have to change the two bearing inside the fan housing... I took them out but have problems finding any markers on them... I measured them, but every bearing shop told me that I must know on which car the bearing was used... and since our Flavias are very old, they are no longer listed in catalogues...so... please help me
I will record the sound of the engine as it is now and if someone wants to hear a sporty boxer, let me know...
Best regards, Jaro
Best regards, Jaro
Bert Ewalds
Front fan bearing
Lancia part nbr 2048163 = RIV ALN 12/053=SKF 6201-2RS/C3
Rear Fan Bearing
Lancia part nbr 2048137=RIV ALN 15/103=SKF 6202-2RS
RIV and SKF are well known bearing manufacturers
Bert
Rear Fan Bearing
Bert
jaro
Thank you Bert very much for this information ! I will contact SKF today and ask them for these bearings.
Thanks again !
Best regards, JAro
Thanks again !
Best regards, JAro
jaro
Hello again... I have another question... my carbs SOlex C35 PII are producing a strange whistling noise... it is really not pleasant... And it gets stronger when the revs go up... Do you have any idea what is causing these sounds ?
Thanks, Jaro
Thanks, Jaro
