Vérin de capot AR sur coupé Flavia
Electronic distributor
maurice
Unread post by maurice »
Bonsoir,
Lorsque le vérin ne maintient plus le capot AR en position ouverte y-a-t'il une astuce pour y remédier ?
Il s'agit d'un coupé Flavia Pininfarina 1963.
Merci d'avance
Cordialement
Maurice
Hein Reedijk
Re: Vérin de capot AR sur coupé Flavia
Unread post by Hein Reedijk »
Sorry to answer in English. The spring has gone tired, after 40 years. Remove the spring-assembly. You can then carefully compress the spring-assembly and take out the cotterpin. Decompress slowly and take out the spring. Put a number of rings in the tube and then put the spring back in, with some grease. Compress again carefully, and put in a new cotterpin. This should work (it did for my flavia berlina).
Return to “F85 Fulvia, Flavia, Flaminia, Stratos”
