Brake problems Aurelia & Appia
Appia, Aprilia, Ardea, Artena, Astura, Augusta, Belna, Aurelia, Dilambda, Lambda and earlier
Erik
Unread post by Erik »
Dear Lancia-friends,
The brakes of our Lancia's (my Aurelia B 20 GTS 5° serie and Hans' Appia 3° serie) are sometimes not reliable and are 'gripping' at unpredictible moments. The brake-pedalpoint is displacing from the normal stand (middle) to the top of the pedal. The more on the Aurelia, the clutch-pedal (hydraulic circuit) is suddenly going down to half a stroke.
This phenomen is apearing by an oildispenser under normal pressure and with no or few pedal-use.
In my opinion, but also by experienced mecanics, the brakingshoes are correctly mounted: there is no friction in normal conditions and the brakes are working synchronically on the 4 wheels (the B 20 was tested on a brake rollertestbench).
I hope that someone outside can help us, because we don't understand the problem !!
Greetings, Erik (en Hans)
Erik Vermaelen
Voorspoedlaan 13
B 1700 Dilbeek
Belgium
Tel: +32/2/569.36.19
Gsm:+32/476/42.74.70
e-mail: erik.vermaelen@skynet.be
Brian Long
Re: Brake problems Aurelia & Appia
Unread post by Brian Long »
I am not sure if this will help but I understand that there is a compensating drilling in the master cylinder adjacent to the hole which is connected to the reservoir.
I have not determined how this works but I do know that it is necessary that both of the holes are clear of the actuating cup (rubber) in the master cylinder when the brake pedal is fully retracted.
Erik
Brian,
Thanks for your quick reply.
We mounted last year a new master brake cylinder and I think that the holes are still clear.
Maybe there is a problem in the oildispenser or in the master clutch-cilynder; we have to look at it.
Kindest Aurelia-greetings, Erik
Huib
Unread post by Huib »
The point is that the plungers must retract fully for the cups to clear the holes. You have to make sure the pedal has a few mm of free play before the pin hits the plunger.
Erik
Hoi Huib,
Thanks for the reply - I will check the free play.
Aurelia greetings, Erik
Return to “75 Early Cars”
