I Installed the gear in my Lybra 2,0SW, but the radio / Hifi set doesn't take any notice (of the CD-changer). There is a preinstalled cable in the rear, left hand compartment, but apparently the cable is dead, the MCD6 doesn't react in any way. There is a similar cable comming up in the fuse compartment. This is possibly the same one? What am I supposed to do next? How do I connect to the radio / Hifi set?
Has anyone got a procedure for this installation?
Thanks / Erik
Help needed with Grundig MCD6 CD-changer
Re: Help needed with Grundig MCD6 CD-changer
Unread post by Stu Wilson »
The cable in the car is probably not connected in the front of the car. You should find the connections somewhere around the fuse box. Once clipped together, your CD changer should work ok!
Unread post by letnik »
If you have radio+ navi you need cd charger Becker silverstone 2660 or Sony CDX-T65, CDX-T60.
Cd charger grundig is correct for radio without navi
