I have just bought new lacia lybra and when I turn on my headlights on board check appears what is it?
Please can anyone sand me auto manual for Lybra LX and for Bose HIFI?
Check light on on display and car manual
Re: Check light on on display and car manual
Hello
Do you see an yellow pictogram in the display? If so, then you have a burn lamp.
If all the lamps are OK, and ICS tells you CHECK, it's better to go to an Lancia dealer.
It's strange that you don't have owner's manual, if you bought a new Lybra.
Go to the dealer and ask about this. The owner's manual it's heavy and it's not in English.
In Portugal, it's in Portuguese only.
TIP: Start the engine first, and after 15 seconds turn on the lights (cruise lights), and verify
if the CHECK condition is lighted in the display.
Hope help you.
Hope help you.
This usually means you'll have to replace one of your your so called city-lights (not sure what term you use for these lamps). It's not impossible, but you need special lamps for this, which may be hard to find. To find out which of the lamps it is, switch on the lights and walk to the front of the car to check both sides. The lamp type is H6W.
Owners manual is in english and italian too
