I have a Bravo which has the hubs and wheels fitted from a Kappa. They are 16", because the brakes are 310mm Brembo.
Can anyone tell me the stock width of the wheels, and the ET ?
That would be a great help, so i can find some alloy wheels that will fit!
Regards
Lars Laursen
Denmark
Stock wheel size Lancia Kappe Coupé 20v turbo
Re: Stock wheel size Lancia Kappe Coupé 20v turbo
Hey Lars
Could have answered you in Danish... but this is an english forum so we better keep it like that.
Same question has been asked before but I cannot remember the answer...
Perhaps it helps that the Kappa and Alfa 166 should be identical when it comes to wheels? Must be easier to gather data when searching for 166 instead of Kappa. If this is not entirely true then somebody correct me!!!
310mm Brembo? Are they the same size/type brembo as fitted on a Kappa 20V Turbo?
The 16"? Is it the standard turbo-wheels fitted on Kappa 20V Turbo? Perhaps you got a link with a picture of your Bravo?
Karsten - 20VT
Denmark
Karsten - 20VT
Denmark
Thank you for the answers, but i have done some research and discovered that the wheels currently on the car, ARE Alfa 166 wheels. That means they are something like 16x6.5" ET 42.
Kappa is about ET 20 i think.
Brakes and hubs are from the Kappa, but since its a Bravo the wheels from 166 fits. But thank you for your help!
This is the old owner of the car, but it was in a very neclected state when i got it, so i have been using 3 months rebuilding the engine and some other stuff:
http://www.bilgalleri.dk/html/gal_visbil.asp?ID=97509
- Lars
- Lars
