s2 Fulvia Zagato light problem
Posted: 01 Apr 2025, 13:00
Problem:
Small front lights & rear do not work. Indicators (front/rear) + brake lights work.
Fuses + bulbs are ok + light replay (inside side wing) work Tested a new replay and made no difference. Both do not "click"
When headlights are activated, I hear a "click" from one of the silver relays ( on left behind fuses_
Removed steering wheel light stalk (switch) and no wires disconnected.on switch (soldered) or on connection (below steering column)
All fuses are in Italian!
1) Could someone explain what fuse is for (from left to right, beginning with SPIE ACCENS) + ampage?
2) S2 Fulvia wiring diagram pic? (ideally colour coded)
Behind the fuses on right:
3) What is the black CEAM box for?.
4) What other things could I check to get front small lights + rear lights working?
Could it be the headlight stalk (switch) even if the headlights work?
Thanks in advance
Thanks in advance
