Problem:
Small front lights & rear do not work. Indicators (front/rear) + brake lights work.
Fuses + bulbs are ok + light replay (inside side wing) work Tested a new replay and made no difference. Both do not "click"
When headlights are activated, I hear a "click" from one of the silver relays ( on left behind fuses_
Removed steering wheel light stalk (switch) and no wires disconnected.on switch (soldered) or on connection (below steering column)
All fuses are in Italian!
1) Could someone explain what fuse is for (from left to right, beginning with SPIE ACCENS) + ampage?
2) S2 Fulvia wiring diagram pic? (ideally colour coded)
Behind the fuses on right:
3) What is the black CEAM box for?.
4) What other things could I check to get front small lights + rear lights working?
Could it be the headlight stalk (switch) even if the headlights work?
Thanks in advance
s2 Fulvia Zagato light problem
Re: s2 Fulvia Zagato light problem
Unread post by Fulvia1973 »
Glyn Williams and I developed a couple of handbooks on Fulvia ownership - the first on the Electrics, the second on Restoration. The electrical one answers your question about fuses - and a lot more.
The Electrical handbook can be downloaded for free from the Lancia Motor Club public website by pasting this link:
https://www.lancia.myzen.co.uk/forum/in ... #msg101937
The Restoration handbook can be downloaded using this link:
https://www.lancia.myzen.co.uk/forum/in ... ic=14554.0
Cheers, Norm Thomas
Cheers, Norm Thomas
