I have a question on the switches... 3 rocker ones, first is blank, unused. second blower and then wipers, all fine. Then the knob on far side is the manual pump for windscreen washers - seemingly this is no longer connected and has been swapped to a small electric one under dash - may swap back depending how original I want it.
However, the headlight switch does not seem right. This is the nearest knob to driver (LHD)..and if I'm not mistaken it should be twist to turn side lights on and then pull to turn headlights? with the main beam on the indicator stalk?
Mine seems to turn full circle with no stop and is stiff to pull in and out. I can get the lights on but it doesn't seem quite right. Assume possible to replace the switch?
And is there anywhere to buy replacement knobs... mine appear to be a bit chewed up
